Vektor Golf MK7 R GTI Tuning Data Display
888Gen3
Europe
GOLF MK8 GTI
VEKTOR TEST in VW Golf 7 GTI CS Model 2016:
Unboxing, installation, Live Tests, 100-200 kmh Drags with 30 Hz GNNS/GPS, etc.
(Right and left steering wheel versions available)
888Gen3
Europe
GOLF MK8 GTI
This VAG Data-Display shows ALL values to make sure your Tuner did a fantastic Job.
ENGLISH - Version - You can also do 30Hz GPS time measuring (0-60, 0-100, 1/4 mile, 1/2 mile, 100-200, etc.), Coding (similar: VCDS/OBD11),
checking HP / NM / Lambda / timing & retard / DSG Oil + Exhaust Temperature, Boost Pressure, etc.
Fitting plug & play ALL Golf 7 (GTI 220, 230 PP, 245 Performance + 7 R + GTD, etc. PreFacelift + Facelift)
Is the gps Bluetooth so I can use it with my track apps on my phone.
BecauseMotor
Brooklyn
any more info on this at all? Is the screen in english? MPH? PSI? Temps in Fahrenheit?
888Gen3
Europe
GOLF MK8 GTI
For UK / AUS LHT / RHD also available
BecauseMotor
Brooklyn
I ordered one this morning. Can't wait to get it in and try it out!
888Gen3
Europe
GOLF MK8 GTI
In Stock again (8x Displays) after three months of being sold out worldwide.
staying_tuned
Poconos
2016 Mark 7 Golf R
Analog boost option or purely what had been requested?
BecauseMotor
Brooklyn
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
what is the third unit in the box besides the screen and the vektor unit? Mine did not come with that? :unsure::unsure::unsure:
Looks like the GPS interface to pull the signal from the OEM GPS antenna on the car if fitted???
I still haven't ordered mine yet....holding off to spend the money on a remap & possibly a MIB2.5 swap..
888Gen3
Europe
GOLF MK8 GTI
It is the GNNS (GPS/Galileo/Glonass) adapter modul that is put between original GPS antenna and the vector unit so you can use the originally installed antenna which is very powerful. You get it it only when your car has already navigation system (Media or Discovery Pro) installed. If your Golf 7 does not have navigation system then you get a good GPS Antenna when buying from www.kolbenkraft-tuning.com.
You can choose when ordering.
