I've had my GTI for about 4 years now, and while I don't hate the Fender system, it's time to upgrade. I used to do a little custom car audio back in the day, so I hope I remember how to do some of it! My buddy (also a former car audio installer) and I started on this build a few days ago, but only have a few hours after work each day to mess with it. I expect we will be done this weekend or early next week. I'll update as we make progress.
Here's a picture of Chuy from the outside --> illegal tint and new shoes
Credit where credit is due: I need to send a big shoutout to the guys who did all this work documenting the pinouts and connections for us already!
--> THIS THREAD for the MIB2 pinouts and VCDS coding,
--> and THIS THREAD for the fender amp pinouts
The Fender system is better than a lot of stock systems I've had, but it can't compete with aftermarket gear. Here's what we're going to install:
- Focal 165AS 6.5" components in all four doors
- JL 10" W3v3 DVC 2ohm
- JL 400/4 (75w x 4 @ 4ohm)
- JL 500/1 (500w x 1 @ 2ohm)
- AudioControl LC7i line out converter
First things first: the design.
Like one of the threads linked above, we're going to tap into the back of the MIB2 head unit and recode the system to send speaker level signal out the unused pins. I ordered the missing 8-pin quadlock connector from ECS, but it does NOT come with the pins. After quite a bit of searching and cross-referencing part numbers, I ordered the terminal pins to go in that connector from Mouser. These are the right pins to go in the brown connector:
The signal flow will be:
MIB2 speaker level output -> LC7i LOC -> JL 4-channel and sub amp -> Focal crossovers -> OEM Fender amp harness -> Focal component speakers
Wiring diagram:
Laying everything out in Sketchup:
I originally planned to put RGB edge-lit lexan panels on top of the amps, but decided to scrap that idea and inset the amps a little in the facade instead. I may revisit the idea later.
On to the actual disassembly. We removed seats and all the trim so we could lay sound deadening on as much surface area as possible. The road noise in the mk7 is deafening at highway speeds and it's one of the very few things I dislike about the GTI. I've been wanting to do this for a long time.
The 0ga power wire was way easier to run than I expected. There's already a cutout in the firewall that nothing runs through. The insulation is perforated and popped out as soon as I touched it. Of course the hole is too big, so I'll have to seal it up when we're closer to done. The wire fits nicely in the door sill channel. We're going to fill in a little more killmat in the bare spots today, run the speaker wires, and then start to reassemble the interior. I put sound deadening on the inside of the hatch too, but I didn't take any pics before putting the trim back on.
Test fitting the sealed box. I had a design for a ported box as well, but it was going to be a challenge to stuff a box with that much internal volume in here and still keep the factory floor panel. I want this all to fit under that flooring, so the smaller sealed enclosure won. I used a router to carve out a 1/2" deep indentation on the bottom to accommodate the steel fixture where the spare tire stud locks in.
Test fitting the amp rack and facade/box top. We used CAD (cardboard aided design) to transfer the basic shape of the area to the MDF. There was a LOT of put it in - mark it - take it out - trim it - put it in steps here, but all worth it in the end. I like how it came out.
I mounted the crossovers on the amp rack and started running speaker wires this morning, but had to stop and do my real job. Updates to come later this weekend!
Wiring diagram:
