BTFPTM
- Frankfurt Germany
Hi everyone,
My GTI has a very unsettling behaviour under what I call sporty braking. First some details:
- Bought the car used last winter, 2014 Performance edition, 25k miles
- car has the electronic suspension options and the LSD that comes with the performance package. 6-spd manual gearbox. Stock.
- According to VW service docs, the car is accident free (not a guarantee, I know, but a good start)
- All related components are in good condition.
- Front rotors are new and EBC pads on all four corners are new.
- The new brake parts helped, but did not eliminate the problem completely.
- Brake fluid has been flushed and bled by VW.
- Wheel alignment has been set by VW after having taken the car to them twice, it was always 'in spec' but they added some caster and toe by shifting the subframe around in hope of making the car more stable.
Ok, so the problem is, under hard braking at speeds of over about 90mph, in a straight line, the nose of the car sways back and forth, often starting first to the left and then back to the right. Some details:
- steering wheel does not move with the swaying, it stays pointed forward.
- it does not feel like one corner dips more than the other, the suspension seems to be compressing equally
- neither the ABS nor ESC activates, it's not a panic-brake situation, simply a hard sporty brake situation
- under gradual braking, call it 'not sporty', problem does not occur
It's a very unnerving feeling, especially at 100+ mph (gotta love the German Autobahn), and does not inspire confidence in taking the car to the track which I would very much like to do. VW has now had the car twice, and made adjustments, and the problem is improved but not gone, they say the behaviour is 'in spec'. I disagree, I think a car that's built for 150mph needs to brake down from that speed without the nose drifting side to side, especially when the car is just going straight.
My brother races an oldschool Rabbit, he's suggested that I might be out-braking the suspension bushings, which may be plausible.
Another unlikely but possible scenario I've thought of could be the LSD reacting to the brakes, maybe if one wheel slips a little under hard braking then both the braking control and LSD are fighting to control it.
In any case, I don't like it, and as mentioned it does not inspire confidence in a car that's built for performance. My last car, a Skoda station wagon, did not have this problem, and it was a 150hp diesel beater that I used for work. If that car can be built to brake stably from speed, so should a GTI be.
I'm open to suggestions, any feedback is welcome. Thanks, guys!
