FastLax and myself will be heading to GLD tonight if any of you local Rs want to meet up.
I just ordered new street tires so I'm down next week.. I can make a few passes in street trim before i run the new wheels/brakes
Well gents, my 60's very much improved. Not sure if it was because it was warmer, the haldex tune or the updates on the dsg and engine tune.
I managed a couple 1.73s when best before was 1.8s.
Best time
12.031 @ 113.13mph on the 1.731 60' The air was not as good as when I ran 12.1s and Fastlax was down .1 from last time. That tells me the car is def. making more power somewhere.
Interesting enough my 1/8 mph was slower than last time but I turned a better ET. At the 1/4 both ET and mph were better. So top end def. picked up compared to old tune.
At the end of the day, I was STILL spinning though. My best method came from launching in the burnout box and cleaning/heating the tires up a bit where I got practically zero spin. But when I got to the line it would still spin a bit. I had to launch around 3000 and ease into it. If I could do a real launch and stay in in the pedal I would say this car has 1.6 60's and 11.8s in it.
I'd be curious your launch psi. Mine is set to 10psi.
As of now it's done at flash, set by 1 psi increments.How do you change it and by what increments? (I understand it's UM and adjustable)
It's not a light change in coding I'm sure, or a change you make often, but I'd check with um to see if that's still the only way. Not many tuners even offer it.Ugggh I was hoping not to hear that. wtf
thanks for the reply though
Sent from my LG-H931 using Tapatalk
User adjustable via...what? UM tunes by OBD2, so we'd need to buy a cable? Are you letting an unreleased cat out of the bag again? HahaGolf R and S3 user adjustable launch and NLS(for the manual guys) is coming in the next couple weeks.. It is already out for the GTI and A3. I believe it's a $200 upgrade
Is it possible that your launch from the burnout box, the front tires are a little wet and slip enough to activate the haldex better than after you've done that and get a worse launch? This is my theory that I haven't had a chance to test at the track yet, but to me it makes a lot of sense. I'm not sure I worded that right, but it's similar to what I've experienced.
Yes, you need the UM cable to do it.. It's definitely out, only a few dealers made the announcement.
Can you elaborate? What are the differences you're noticing?UM’s Haldex tune is fantastic! Just had it installed on my S3 on Monday and boy what a difference.
Would you say you feel the rhythm or the rhyme more now?
