Hello, I have posted about my issue before, but this might be the best place to ask again since this thread is about crankcase pressure. My car has an issue with oil leaking from my Vortex XL turbo from the V-clamp between the turbine and compressor housing. It has been happening for a year and a half now. From what I can tell, the leak occurs anytime the crankcase pressure becomes atmospheric or positive. The stock MK7 PCV seems to keep the best vacuum on the system while at idle and I get "almost" no leaks. I notice a drip or two at the v-band after driving 1000 miles or so. I'm positive it's coming from the v-band, so you don't need to entertain the idea that it's coming from anywhere else. The problem of course is smokescreens after hard pulls, the OEM PCV doesn't last long (my latest one lasted 2 months), and the drips of oil that make my car smell like burning oil sitting at red lights. I have tried the APR and 034 PCV plates and since they both eliminate the vacuum tube under idle, they both create the oil leak, except it's so bad that the oil drips onto the downpipe, then smokes, and it looks like my car is on fire or overheating. I have recently converted to the MK8 PCV and I have found that it creates more pressure than the MK7, but not as much as the APR or 034 plates. This is also confirmed by the OP's testing in that the stock PCV makes -3inHG and the MK8 makes -1.5inHG. The leak is back with the MK8 (although not as bad as the APR and 034 plates).
I pulled the turbo off a year ago and checked all of the drain lines and the v-band. I have spoken to EQT countless times about this and they claim I have a crankcase issue. I have compression and leak down tested my car and it is perfectly fine on all 4 cylinders, so I don't know what crankcase issue they are speaking of. Currently, I want to pull the turbo and ship it back to EQT for inspection or rebuild.
My question is does that seem reasonable to you that the turbo is the issue? Is there anything I could check first before pulling the turbo OR once I pull it, is there a test I could do to confirm a weak seal? Maybe plug the drain and fill it with oil and see if it leaks? I have had this issue ever since going Vortex XL and never had this issue with the IS20 or IS38.
