UM haldex tune - how to verify?
RudyH
Kitchener, ON
So I had my car into the shop for a new condenser installed by VW. When the car came back it seemed odd, something changed besides the AC condenser.
One thing that was pretty obvious was the power seemed lacking - like there was power but not Stage 2 power levels. I flashed the car and suddenly the car woke up again.
I only went for a 15-20 min drive after, but I wasn't able to completely open things up. It *seems* that the rear end is there, but I feel like it's not as lively as it normally was. I wonder if after installing the AC condenser, a reset or flash by the dealership was done?
Is there an easy, besides going to a UM dealer, to verify everything is active and working? Anything through OBDEleven?
It definitely doesn't feel like there is no rear end, but I feel like there was more before
yakev724
NYC
2015 S3
I think if I access the respective modules in VCDS (not sure about ODBEleven) the UM file name shows up as one of the first lines in the scan.
RudyH
Kitchener, ON
Module 22, All wheel drive, Info, Software version. If it has UM software it should show UM03.
first thing I check when I go to my car at lunch - was a busy day yesterday to check forums on this
** checked at lunch and indeed it was there, I think after reflashing to Stage II, needed to let things kick in, power is there and definitely feels like how it use to now. I think there is some adjustment period for things to settle in
Mosquito
I do a pump prime every now and then to make sure it is still alive and doesn't get lazy.
krs
Las Vegas, NV
MKVIIS R
Is this haldex tune worth the money? I can't really find a bunch of info on the pros/cons. Wondering for autocross reasons....
RudyH
Kitchener, ON
definitely if you are tuned, it feels less like a GTI and more as you would expect froma R. I found it compliments a Wavetrac LSD beautifully.
Honestly between the two items (among other mods), makes this car very hard to replace without spending double the money at this point
tigeo
  • Like
Reactions: krs
sterkrazzy
United States
Turbo. Blue.
My closest dealer is 3 hours away 😮
sterkrazzy
United States
Turbo. Blue.
Is it worth it even if you're just stage 1 and don't often push the car that hard? I'll probably never take it to a track. I might rip it around the occasional corner, but I do a fair amount of 0-60 pulls.
tigeo
No it's not.
pdisguise
The more power you make over Stock the more you’ll notice it. Stock Haldex can only send 50% of stock power to the rear. Once you mod all that power goes to the front only.
