railroader
- Yuma Arizona
Burger jb4Which do you like the most?
Sent from my SM-G955U using Tapatalk
Sent from my SM-G950U1 using Tapatalk
I kept the Neuspeed.
I used the JB1 for about 200 miles and took it off. I didn't feel as smooth as the Neuspeed.
I've been running the 7psi mode with 3.5 gallons of e85 and topping it off with 91.Can you run the +7 psi on 93? Neuspeed told me I could.
Hahah DSG will handle it better than stock manual. Manuals typically need clutch upgrades, after that they are fine.
Stock DSG will handle 350 just fine but it can’t hurt to get a DSG tune for better performance.
Sent from my Mi A1 using Tapatalk
Burger jb4
How do you compare jb1 to jb4?
Is the jb4 near 300 hp?
You can run it on 93...but as mentioned earlier...the difference won't be that much more than on 5psi.Don't have e85 anywhere near me
I only had jb4 but read a lot prior and the jb4 has much more adjustability and a smoother power deliveryHow do you compare jb1 to jb4?
E85 on the 5psi mode makes a noticible difference too. It made a difference on all three modules.
Any independent synod of that ?
