Here is a little comparison between my Vortex xl and my tpc700, these were done on almost same identical map, xl had some cam phasing and 700 did not. Wastegate map was the same and untouched for the two. The xl started to spool a bit sooner bit the 700 made target boost faster. Vortex has a 54mm comp wheel vs 58mm for the 700. I'll have more data on the 700 soon, I need to go on the dyno as I'm at 36psi right now and Wastegate duty is only at 80% my xl around 34psi was tapped. My tpc700 will do 40psi just fine I believe. Also the xl was done in cooler weather where iats were a bit lower than on the tpc.both logs are 4th in my S3
