dwvw
- Red Deer Alberta Canada
In case anyone isn't following the Tomioka thread in the GTI section I'll post this here.
First the car. It's a 2016 Golf R DSG. Has an Integrated Engineering intercooler, Integrated Engineering open intake, and a custom AFR Autoworks Inconel downpipe. Also a Racingline 90 degree elbow. Other than that the car is bone stock. Stock fuel, stock catback, and even has the original spark plugs.
Previously the car put down 330whp On the Dynomite Dyno at AFR Autoworks. At the time it was on an early non adjustable Eurodyne Stage 2 93 octane tune. About 3 months later it was dyno'd at Calgary Autoworks on their Dynocom and put down 360whp with no changes from the AFR dyno. This shows us that the AFR Dyno is nice and conservative.
We bolted on the Tomioka IHX475 turbo, flashed Eurodyne Maestro, then loaded the Maestro Stage 2 high torque base file. Took the car for a few pulls to make sure the wastegate adapted and strapped it to the AFR Autoworks dyno. It made 380whp with no changes to the base map.
Finally we started tuning and were able to achieve a peak of 415whp, but dialled it back to
410whp on 93 octane, we then added 116 race gas till we got a 105 octane mix. The car then was able to put down 450whp.
It started snowing here while we were on the dyno so we could not do a road test immediately after the dyno.
Tonight we were able to get it out on the road and do a couple logs. We see a couple small issues. I am going to be ordering new spark plugs this weekend a couple heat ranges colder than stock and see what happens.
I have a Dragy and will post some results once the roads are fully clear and I can get some real tires on. I will also be attending street legal 1/4 mile here when the track opens in a couple months. On the 330whp stage 2 tune I was able to achieve an 11.95 @ 115mph. That was with the rear seat removed. I have since purchased a lightweight battery and will be pulling the front passenger seat for at least one of the passes.
Any questions let me know.
