JC_451
- NJ, one of the nice parts.
- 2017 GTI Sport
It's not a threat.
It's just an unfunny joke.
It's the vaccine and their deformed red blood cells, obviously. SCIENCE.
Say hello to the new Apologist.It's not a threat.
Literal GTIfan99.When people start talking about hunting you down, it's no longer a joke, and needs to be reported to authorities. Like I said, I have his information. It's the second "joking" threat in 2 days.
Keep fucking around and see what happens.
Literal GTIfan99.
We literally live in a country with the most gun violence in the civilized world, so threats aren't jokes. Next threat from zrickety will result in a criminal complaint and notifying his employer.
points off for saying "rifle" instead of "one" in the third line!it's Haiku time!
this is my rifle
there are many like it but
this rifle is mine
Thanks for the explanation! I was only thinking about the sweep of the pick itself without considering its angle in relation to the handle. Now it's very obvious that the rightmost one is a better anchor.All different styles for different uses. the fist three are walking/mountaineering ice axes, & will do steep stopes, but are not for vertical ice. The shortest/yellow one on the far right is for vertical ice with the reverse pick set at its steepest angle. This is very good as it places the weight down onto the tip of the pick for shallow placements usually on very hard ice..or what we locals call "Cairngorm concrete"..which is ice so hard the ice axes usually bounce off on first strike!
You will also note that the shaft of the axes gets more "bent over" the more "technical" they are. This again helps with the swing & ease of placement, especially when "topping out" i.e. getting over the top of the climb. You will also note that those three still have a fairly straight bottom section to the shaft which is good for plunge placement on steep slopes. These days the axes can be really bent right over, & have addition hand grips for the most technical vertical ice climbing eg:-
Switch | Winter Equipment | DMM (dmmwales.com)
Dark Machine X – Grivel
5-7-5points off for saying "rifle" instead of "one" in the third line!
One of two for the entire state.5-7-5
also NM area code
Just the tools alone trigger my fear of heights. Y'all have some serious sack to be doing that shit in the first place.
Threatening to make this thread real life, notifying employers etc will result in a ban. Cut that shit out, there won't be more warnings.
This is a joke thread for fucks sake.
