At the moment the car is custom made from a Lotus Elise, it cost $109,000; but its the first step by a company to made a reasonable car
A full charge takes about 3.5 Hours to charge.
225 Miles per charge , cost is about 2cents per mile
Batterys last atleast 100,000 miles
Tesla Roadster Technical Data
Motor
Type designation 3-phase, 4-pole electric motor
Max net power 185kW
Max rpm 13,000
Efficiency 90% average, 80% at peak power
Torque see torque curve chart
Transmission
Type: 2 speed electrically actuated manual transmission with final drive; constant mesh gears and inertia lock key type synchromesh
Gear Ratio Overall
First 4.20 : 1 14.3 : 1
Second 2.17 : 1 7.4 : 1
Final Drive 3.41 : 1
Reverse reverse direction of motor
Front Suspension Type: independent; upper and lower wishbone; co-axial coil spring/telescopic damper unit; anti-roll bar
Rear Suspension Type: independent; upper and lower wishbone; co-axial coil spring/telescopic damper
Brakes
Type: Cross-drilled 300 mm front and 310 mm rear discs with curved vane ventilation; AP Racing Two piston Aluminum fixed front calipers; Brembo Single piston sliding rear calipers
Operation: Vacuum pump driven Servo assisted with 4 wheel ABS system
Wheels
Type Forged Light alloy
Size - front 5.5J x 16
Size - rear 7.5J x 17
Tires
Type Yokohama Neova AD07 LTS
Size - front 175/55 R16
Size - rear 225/45 R17
Dimensions
Overall length (in. / mm) 155.4 / 3946
Overall width - incl. mirrors (in. / mm) 73.7 / 1873
Overall height (at curb weight) (in. / mm) 44.4 / 1127
Wheelbase (in. / mm) 92.6 / 2352
Track - front (in. / mm) 57.6 / 1464
Track - rear (in. / mm) 59.0 / 1499
Curb weight Around 2690 pounds (subject to complete safety and durability testing)
Leg Room (in./mm) 42.0 / 1067
Front Head Room (in./mm) 36.7 / 932
Front Shoulder Room (in./mm) 26.0 / 660
Standard Interior features
Heated sport seats with inflatable lumbar support
Three-spoke leather-wrapped sport steering wheel
Smooth leather seats and trim in black, dark gray, light gray, or beige
Blaupunkt stereo sound system with single-disc CD player, iPod interface, and MP3 playback
Cruise Control
Homelink universal transmitter to operate compatible garage, gate, and home lighting/home security systems
Power windows and locks
Air conditioning
Single retractable cup holder
Standard Exterior Features
Double-insulated black soft top
Proprietary halogen low- and high-beam headlamp assemblies
LED tail lights
Forged uni-directional seven-spoke wheels in silver finish: 16" front, 17" rear
Locking wheel lugs
Tire Inflator/sealant
Cold weather ESS heater for cold weather charging to -20 degrees Celsius
Home-based charging system with integral safety features for 3.5 hour full re-charge
Standard Safety and Security Features
Four-sensor, four-channel Anti-lock Braking Systems (ABS)
Traction control
Tire pressure monitoring system
Front and rear crumple zones
Driver and passenger front airbags
Rigid occupant safety cell
Side impact door beams
Seatbelt pretensioners
Integrated headrests
Vehicle theft-deterrent and engine immobilizer system
PIN for security in operating the vehicle
Valet mode to restrict speed, acceleration, and distance
Factory-installed options and accessories
Premium leather seats available in nine colors with embroidered Tesla Motors logo
Microfiber, non-leather seats in black
Bluetooth cellular phone integration
Satellite radio with 170 channels of digital sound
Seven-speaker premium sound system tuned for Tesla Roadster cockpit
Touch-screen navigation system with voice guidance
Matching body-colored carbon fiber hardtop with full headliner
Metallic and premium paint
Tesla Motors custom floor mats
Mobile charging system
