Hi, I am new here and have a 15' TDI and was looking to upgrade the 16" wheels with a set of HYPERGRAM 18 X 8.5 ET 43. Anyone else with pics or a long term review? I also understand that you have to replace your lug bolts with these wheels. Anything else needed to complete the install? Thanks
Hub rings (66.56 to 57.1) and conical bolts.
Does someone know which aluminum hub rings (66.56 to 57.1) have a tight fit ?
Thanks!
I'd stick with plastic. That's what I went with. I've used them in the past with high mileage and had no issues. I did think about using aluminum for this wheel set...then reading about how they can seize on the wheel/hub changed my mind.
You can even skip the hub ring all together if you install the bolts correctly.
Does anyone know for sure if the Hypergram 17x8 et45 wheel clears the PP brakes?
