Gawernator
- Fremont, CA
Ah understand. Do you think I will be ok with 235/40/18s? 42 offset
Yes that’s my size
I forgot to mention 8 1/2" wide rim. Do you think the 235/40/19 will be stretched?Yes that’s my size
Added a 15mm spacer to the rear with 40mm bolts. Got rid of the sunk in look at the rear wheel. I really like how the front brakes look behind the spokes of the wheels.
Sent from my Mi A1 using Tapatalk
In my own experiences...I've never had wheel bearing or suspension issues with any of the cars I've run spacers on. These spacers aren't that thick.
It's really no different than getting wheels with a lower offset. It not the spacer that would cause issues with the wheel bearings...it's the leverage created by moving the wheel farther out from the center of the hub that has the potential of putting more stress on the hub.
I was originally planning to put the 12mm from my front stock wheels on the rear of the Hypergram...but the center bore of the 12mm isn't deep enough to fit over the hub of the rear wheel...so I had to move up to the 15mm.
Looks good. and i love the Mazinkaiser avatarAdded a 15mm spacer to the rear with 40mm bolts. Got rid of the sunk in look at the rear wheel. I really like how the front brakes look behind the spokes of the wheels.
