Superpro to be offering new fixed camber plates
yirayira
Chicago, IL
2015 GTI SE
demi9od
NC
Can you point me to a 034 camber plate failure?
I don't think you'll find one. Their motor mounts have failed and that's probably what he is referring to. The camber plates are unlikely to imo.
I'm surprised the SuperPro are cheaper, their stuff is usually mucho $$$.
Sent from my LG-H910 using Tapatalk
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
Is 1.4 degrees some magical number for extra camber?
Since these Superpros add exactly 1.4 degrees just like the 034 ones, were Superpro engineers saying "Let's do the exact same thing as these other guys 'coz f*ck options" ??
..while at the same time offering 2 different LCAs with different caster..? :confused:
MonkeyMD
More likely is they're exactly the same product
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
They look clearly different:
Or it's a space limitation within the strut tower
That's a possibility, we would need someone who's played around with adjustable camber plates to chime in.
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
The GSW (and I suspect the standard Golf) both have big coil OD, around 6.25".
When I first received adjustable Vorshlag plates, I could only get 3/5 adjustment on the drivers side before the spring would rub on the inside of the strut tower. This was roughly at 1.5 degrees adjustment...so yeah these fixed plates could be addressing the packaging.
donefor
usa
I have the 034s and in my case a small amount of grinding (about 1/2") to the shock tower aperture was required to keep the top of the strut shaft from contacting the edge of the aperture (on KW V2s). A minor gripe really, but do have the grinder ready. ;)
teemmy
bay area, CA
Just mounted these on and they’re great. But i also had to take a grinder as the top of my front dampers came in contact with the opening...
teemmy
bay area, CA
First impressions - these are great. Early turn in understeer and mid turn understeer is eliminated. Very little NVH - maybe a tiny bit of increased noise over harsher bumps, but not much at all.
Really happy with these and I highly recommend.
GolfRRRR1
Michigan
Wow, I guess I didn't expect them to require grinding. Do the 034 units require grinding out the tower too?
Teemmy, any more thoughts on the improvements?
yirayira
Chicago, IL
2015 GTI SE
Now 1.4 makes perfect sense. With coils I'm able to run 2.4+ on the Vorshlag plates with plenty of clearance
I cut the tops of the towers to enlarge the holes for easier caster adjustment. The cowl covers the tops so it's not noticeable. Plus all the cool kids are doing it!
Swoope
orlando
hey,
what suspension are you on now, and how much have you lowered it?
what did you end up with for camber after alignment or check?
i put a hard day on sebring long course and was shocked at how well 200tw tires held up camber wise compared to the pss.
beers
Mk7Will
Temecula
You have to cut/grind your shock towers when you have an aftermarket coilover I use the 034 mounts with KW's and I had to grind out my shock tower. The factory shock thread length is not as tall and will fit under
