1. For the fender sub wiring, which of the two wires with the yellow line is the ground? (I know that the brown/Yellow and White/Yellow is one set, and then the Brown and White is the other, but I don't know which is which...
2. Is the Yellow striped pair, the Left or the right speaker for the LCi2?
3. You said you found some write-up on setting the amplifier and the LCi2 correctly. Any chance you could share that page? I am not the best at all this
Chid: I understand what you were trying to do by connecting directly to the battery terminal, but it sounds like anyone who gets their power supply this way will need to destroy the nut on the battery clamp (and then they will need to buy a complete new clamp from VW).
An almost-as-good alternative seems to be use one of the nuts on the SA fuse holder in my pic above. Any nut will do because the size of the copper bus in the SA fuse holder is quite substantial. The good thing about this alternative as a point of electrical coupling is that the cable that is connected to 508 is very short and it is very fat in cross section and it is connected directly to the battery clamp (the nut of which has to be destroyed if the alternative isn't used). What this all means is that the bus on the SA fuse holder is "electrically close" to the battery terminal - hence it is a good alternative!
Just putting it out there for others to consider!
so i need some help figuring out the gains. i never used a line out converter before. im going to be using a steve meade distortion detector, i guess i have to find a way to tape the damn door speakers so that i can get my initial readings figured before moving to the sub amp, but how do you figure the gain on the lc2i? then i do it again on the amp itself? inquiring minds would like to know
This thread was awesome. Got my 2 12" sundowns in this weekend. Love my GTI even more now.
I did pretty much the same thing as this settup except I don't have an LC2i. Does the LC2I make that much of a difference in terms of adding the lower frequencies (40~60hz) that the Fender system seems to omit? It drives me nuts listening to music that hits hard and then when it goes a little lower, it just disappears. I know my sub and amp can handle it.
good thing i bought one tooFrom what I understand the factory system has some sort of sub roll off (to protect the factory speakers from blowing) I think it's called? The LC2i is supposed to restore the bass from that roll off...I'm not sure how you would measure this but from my research that's a big selling point of the LC2i.
