pseudorealityx
- Decatur, GA
- 2017 GTI SE
Also... nobody willing to share ride heights, wheel center to fender?
Finally speccing out Ohlins (stock issues, yay!) Probably going with the older, basically-stock-ride-height version but I'm fine with that. Thinking keeping stock front (70N/mm - 400lb/in), revalved and up-sprung rear (110N/mm - 635lb/in). Puts my roll couple somewhere around 64% including my roll bars, with adjustment to go softer rear/stiffer front. Revalve should allow me to go up to about 130N/mm (740lb/in) before I start having problems with underdamping.
This all seem reasonable in an R that also sees a lot of DD use?
Looks good for an aggressive DD setup, with adjustable bars / alignment doing the restFinally speccing out Ohlins (stock issues, yay!) Probably going with the older, basically-stock-ride-height version but I'm fine with that. Thinking keeping stock front (70N/mm - 400lb/in), revalved and up-sprung rear (110N/mm - 635lb/in). Puts my roll couple somewhere around 64% including my roll bars, with adjustment to go softer rear/stiffer front. Revalve should allow me to go up to about 130N/mm (740lb/in) before I start having problems with underdamping.
I can share mine if I remember to measureAlso... nobody willing to share ride heights, wheel center to fender?
I'm not saying that you are wrong. Your "evidence" has been non-existent.I'm not even sure how it's debatable? But keep beating that horse.
If this is true it's a great example. I didn't know this until right now. @xXDavidCXx have you seen that?Ok..how about Ron Williams? 255 front, 215 rear in the civic last month, in Lincoln.
Interesting. The Heaton's were on the Kumho too in Chicago.He was testing the new Kumho's on that setup.
I have been out of the country, so I haven't seen anything.If this is true it's a great example. I didn't know this until right now. @xXDavidCXx have you seen that?
I just want to know who got close enough to Ron’s car to figure that out.
Wonder if he does that to avoid having a rear bar? Did he swap the front and then get rotation by staggering his tire sizes?
Primarily DD, 1-2 autox a month, right now no HPDE but hoping to do a couple a year starting next year.Autocross? HPDE? What are your actual goals within those arenas?
What I'm getting at is... while the Ohlins are awesome, it's not like there's no other options. (If this has all been covered, ignore this)
Yeah, may have found a backdoor to getting some relatively soon. Will know more in a week or so.I ordered Ohlins back at the beginning of April and its my understanding they are getting ready to ship 'any day now'. Good luck
It's just that I looked into what you said and as far as I can tell your "stacks of jackets" thing wasn't confirmed in the results.Got it, my 2 examples aren't evidence, the 1 example is.
