This looks like a lot of tire lift to me. It's not about the height of the tire lift, it's about the duration and frequency. This looks like you were lifting in slalom-ish stuff. You only want to be lifting the tires around the apex of a max lat G turn. If the tire is lifted all the way through the turn it's a problem to work on (in ST_ trim).
If you are having tire lift, adding more rear roll stiffness is not going to do anything except give you more tire lift and start lifting the tire earlier. Once the tire is in the air, the rear cannot transfer anymore weight and all the remaining transfer goes to the outside front. It doesn't matter if you have 400, 600, or 700# springs back there. I have been down that road and spent a lot of money making my car worse.
This is why I've been suggesting that you don't have a rear end problem, you have a front end problem...
I understand you were talking about going up in spring and down in bar, but what is the point? That bar change is going to change your roll stiffness (soften) way more than the spring change. I dare you to put the 650s on the front and the 750s on the rear and leave the rear bar.
