Diggs24
- de plains! de plains!
- 2015 GTI
Sounds like a tune issue but without a log to see who can say....
No this is a very different issue to what you've described. There is no jolt and the power loss is subtle, it just simply feels like the car goes flat after gear change and doesn't pull as strong. There are also no fault codes when scanned with VCDS.
Any update on this? This exact thing happend to me today. 2017 dsg Golf R with APR stage 1 ECU and TCU tune. This is the only thread I found with the exact issue. Did the new PCV and/or downpipe fix the issue?No this is a very different issue to what you've described. There is no jolt and the power loss is subtle, it just simply feels like the car goes flat after gear change and doesn't pull as strong. There are also no fault codes when scanned with VCDS.
Welcome to the forum. That is weird. Are you tuned? How hot was it? In Drive or Sport mode it doesn't do it?Any update on this? This exact thing happend to me today. 2017 dsg Golf R with APR stage 1 ECU and TCU tune. This is the only thread I found with the exact issue. Did the new PCV and/or downpipe fix the issue?
Only happens in "manual" mode, only when in third gear and at 5k rpm. It is very consistent. Weird.
Thank you!Welcome to the forum. That is weird. Are you tuned? How hot was it? In Drive or Sport mode it doesn't do it?
I don't know then. There's no logical reason why it wouldn't happen regardless of what mode the trans is in. Must be a peculiarity of the DSG tune.Thank you!
Yes I am tuned. APR stage 1 ECU and TCU tune. Only happens at WOT, in third gear at 5k RPM in "manual" mode. I tested the car twice today. Both times oil temp was around 212 degrees farenheit. Outside temp was 86 degrees during the day and 76 degrees at night. I tested it numerous times during both the day and night session and it is super consistent- happens at the above parameters every time.
Oddly, in standard drive or sport mode, it doesn't lose power at WOT, only in "manual" mode it does this. The only thing I can think of is that the car is limiting itself. Maybe torque limiter? I'm not a car expert so I could be completely off.
Thank you for the quick input. I would agree and hopefully it will not cause damage to the car over time. I guess I will avoid manual mode just in case. Thanks again.I don't know then. There's no logical reason why it wouldn't happen regardless of what mode the trans is in. Must be a peculiarity of the DSG tune.
