St2 paddle shifters
MKay7GolfR
California
Super easy install, used dental picks to get the pin to pop out. Much easier than using needle nose pliers. Took about 5 min and I think it can be done in less time.
Hondan
OC CA
ST2 B3 paddle shifters
Here are some pics I took. I could not reach the stock paddle with my hands at 10 & 2. Now I can get a couple finger tips on them. The fine detail of the machining in this part is top notch.
These are pricy but I decided to go with an "upgrade" rather than a "bandaid". I am happy with this purchase. It's worth the money. It's easy to see that there is a lot of time involved with machining this part. The feel of aluminum also gives the car more enjoyment.
This two pice part (each side is assembled from two pieces) has some very fine detail with small pocketing and very thin sections. The paddle is one part and the pad that pushes the mini buttons is a separate part. It looks like they slide together tounge and groove then permanently attach with epoxy.
The only critique I have is the left side has a tiny bit of play. I mean it's so small it could be anodizing tolerance. I also wish they were just a mm or 2 wider, but I have stubby fingers.
dongdong
sf bay area
looks good! did you get the black anodized one?
i just installed mine yesterday. only down side for me is that when i have the AC going, the left pedal is cold!
