Riddick20
- Parma - Italy
this Sunday if there are no unexpected events I will do the first part of the job ... I change my BCM with a suitable and active 30 colors on the discover pro.
Green to orange/brown, and Brown to orange/purple.did you connect behind the canbus line of the radio?
you can put the photos with the connections and the colors of the cables as they should be put?
Thank you.
Yesgreen and brown are the cables of the main module of the kit?
Which kit are you using?@IWMTom
if i want to do an oem job and then connect to the bcm from what i understand i need 3 cables that i have to connect.
- negative
- positive 12v
- line lin
do you know which are these 3 pins of the BCM in which to put the new wiring?
You wouldn't be able to use this kit without the modules.i will use a kit like yours ... but i would like to connect directly to bcm and not use the seller's modules.
do you know what these pins are?
With this kit, yes, you would need to use their modules and connect to the CAN lines on the Quadlock if you're looking to use the OEM screen controls.so the only way to connect and get everything working from the radio screen is to attach to the canbus line?
what did you use? any clamps like this?View attachment 202034
6 and 12.https://pinoutguide.com/Car-Stereo-Volkswagen-Porsche/Volkswagen_E-Golf_2014-20_pinout.shtml
pin 1 and pin 7
or
pin 6 and pin 12 ?
