Chillout
- the Netherlands
- SEAT Leon FR ST
Is this something you could do with an odbeleven? Sorry new to VWs.
Anything you can do with VCDS you can do with OBDeleven Pro.
You know you don't have to floor the car every time you take off from a stop right?
Increased traction for the VAQ paired with good tires would also fix your issue.
I also notice with starting vibration off, my car did vibrate a lot more in idle. Not sure if that was related, but seemed to relax when I put it to standard.
Just set my ESC button to act as ESC ON/SPORT ESC/ESC OFF and set the starting vibration reduction to deactivated, torque limiter was already deactivated.
Launched it a few times with ESC off and the vibration reduction deactivated. Holy crap, does it launch WAY better, and the tires chirp a little instead of just hopping. I just got new Firehawk Indy 500's though and I don't wanna burn them up immediately so I set vibration reduction to NORMAL, it was on STRONG. Or am I thinking about this wrong?
EDIT: I have the PP with the diff if it makes a difference. I wanna be able to launch it when I want, but under normal driving circumstances still drive safely without having to worry about wet surfaces or burning up tires.
Hopefully you guys can help. With OBDeleven Pro the starting vibration option doesn’t even show up under adaptations. I have a ‘19R.
Thanks all!
My 2015 has it under a blank field name. So click through all the options and you will probably stumble across it.
I don’t think there were any blanks but I’ll look tomorrow. It might be renamed. I set the XDS to strong and that felt like a good change.
People have recommended against that due to the unpredictability of it. Some folks had issues with it kicking on on-ramps and almost getting in accidents because of it.
From my experience the strong setting at low speed seems to help the front end bite and reduce understeer. At higher speeds it can be a detriment and cause understeer.Really? Interesting. I’ll pay more attention and see how it drives. I can always change it back
