George Ab
- Pacific NW
I had a knock/noise when I initially did mine. When I followed the instructions in the video (post #11) above of putting suspension under load and then torque bolts it resolved my issue.
I run a 27mm with moog
Edit: sorry looked at what you said, i think its hit or miss the stock endlinks are plastic junk, you might be able to get away with those for a bit but they usually tend to pop/creak after a bit of wear n tear.
Oem are plastic, moog are steel, more durable yesso sounds like the concensus is replace them while you are there?
also n00b question, the Moog links are just steel link? Only adv over OEM is durability?
they are out of stock on the MOOG links now.
thinking about getting a 25mm RSB - anyone run that size with stock end links ?
trying to save $ if i can. thanks
did you order? I was thinking about trying my luck to run without new endlinks, last time i was under the car things are pretty clean and seems to be in shape.Im in the same boat. Moog is sold out everywhere. I put an order in anyway at summit yesterday. Originally it claimed delivery date of Jan 10 but I checked just now and it says delivery Dec 10, so my fingers are crossed.
it now says 1/4
