I have a set of Racingline 70mm studs installed on my mk7.5 Golf R. These are advertised to work with up to 10mm spacers.
My Macan brake upgrade will require 10mm spacers up front, which is not an issue. I would like to also put 10mm spacers on the rear to match, but I am seeing people having issues with hubs not seating correctly. 10mm is too short to sit on the hub properly. ShopDAP has claimed an 11mm spacer will solve the hub issue. Is 1mm extra a bad idea on my studs since they are only rated for 10mm?
Or does anyone have 10mm spacers in the rear that do not have hub issue that can respond?
