Random epc and limp mode. need help tracking.
Chadastrophic
St Petersburg, FL
'17 Golf GTI Sport
No input on your problem, but you don't have to click the cruise off. Just mash the gas and when you're done let off and it'll settle back to your set point.
toothofwar
KY
2018 Golf R
Just as I thought. Ni dice with obd11. I unplugged the secondary o2 sensor just in case. No check engine light thank God. I have lightly beat on it a bit after tonight's oil change, and so far I haven't had an issue, but that probably won't last.
toothofwar
KY
2018 Golf R
I click it off due to the delay. If the acc thinks there is a car still there, it cuts power drastically until it thinks the coast is clear. Once clear, it gives you the beans.
toothofwar
KY
2018 Golf R
Your tune is EQT correct? If so I thought codes could only be pulled with Cobb and not with Obdeleven and VCDS?
I didn't know that. I might flash to stock and retry it.
Daks
Toronto
GTI PP
STFT are fine. HPFP dips a bit at the shift but nothing abnormal for an IS38 pushing that much boost. Also, he said his misfire issue was in gear in the 5-6k range.
What does it look like when stft is not fine? What's the threshold?
Acadia18
dang
yo
toothofwar
KY
2018 Golf R
And again this morning it happened again. This evening I will be reverting back to stock tune to see if it still happens.
toothofwar
KY
2018 Golf R
Unfortunately no. I want to try a carbon cleaning to see if it helps. If I keep this car till spring I'll report back. How many miles do you have?
Devanl310
Ohio
2016 Volkswagen gti
I’m currently sitting at ab 111k but issues arose ab 500 miles ago. First it started from a stop I get epc & misfire codes, now only happens in 3rd WOT
toothofwar
KY
2018 Golf R
No, unfortunately I traded the car in for a tiguan.
