- Phoenix
- 2018 SE DSG
So APR is bottom barrel?Sounds like maybe you're not the one to listen to about proper maintenance But yeah, that's what happens with bottom-barrel engine management products.
There’s not a single documented case on this platform in someone getting td1d via ecu values. The ecu is seeing stock values. Unless you have fol stupid high, the values are all stock ones. The only physical evidence that’ll be left behind is a visible hole from the afr tap.You can get TD1'd for the increased torque/boost they'd see on the ECU. No harm in *trying* to get warranty work done after running one (I won't judge) but don't assume it's a free lunch. I've talked to enough guys who've seen JB4 cars lean out to never want one on a car I'd buy.
Don't leave home without it.The only physical evidence that’ll be left behind is a visible hole from the afr tap.
I'm the last guy to defend APR but if their tunes were so bad how do you explain their lasting popularity? They wouldn't be around if their tunes blew up that many engines plus they do offer an extra cost warranty. Also why would so many VW dealers tune using APR. All tuners have had engines blow and it's not necessarily the fault of the tune.Yes, and their tunes are responsible for blowing up engines. There couldn't possibly be any other explanation...
Yup. Ordered as soon as I got the jb.Don't leave home without it.
https://www.ebay.com/itm/Fits-GTI-V...145257?hash=item3b3817a969:g:riMAAOSw4vFfLuVr
I know APR gets a lot of shit, but at the same time I give em some slack as they are the most popular tuning choice and by volume handle more customers. Higher sample size means more issues are bound to pop up. I'm sure even EQT had some freak issues happen that would have happened regardless of tuner but they just drew the short end of the stick. APR does release good products and they at least spend time to R&D instead of solely ripping off their competitors and going to a china vendor then slapping their name on it. I also have a gut feeling that competitors do negative press on APR to boost their own company. No proof, but I've worked at companies long enough to know shit like this happens. Doesn't take much to make an account and state "this competitor's tune blew my engine!". However, I have seen a lot of trusted members on audizine and here bring up APR in a negative way so I am wary of their tunes.I'm the last guy to defend APR but if their tunes were so bad how do you explain their lasting popularity? They wouldn't be around if their tunes blew up that many engines plus they do offer an extra cost warranty. Also why would so many VW dealers tune using APR. All tuners have had engines blow and it's not necessarily the fault of the tune.
Can you show evidence of this anywhere? Not trying to discredit your statement but it would be beneficial for individuals to see the evidence of this. Big pro of JB4 is the ability to remove and take to dealer for warranty claims and NOT flagging TD1 due to ecu still receiving stock boost values hence “piggyback” however I could be wrong, not an expert. Just would like to see evidence of TD1 with jb4 being culprit.You can get TD1'd for the increased torque/boost they'd see on the ECU. No harm in *trying* to get warranty work done after running one (I won't judge) but don't assume it's a free lunch. I've talked to enough guys who've seen JB4 cars lean out to never want one on a car I'd buy.
No he can't provide evidence. He's an anti tuner. He said he's seen evidence of a JB4 leaning out. Since a JB4 only boosts the stock tune the stock tune must have gotten severely lean and in that case without the JB4 it would have run even leaner.Can you show evidence of this anywhere? Not trying to discredit your statement but it would be beneficial for individuals to see the evidence of this. Big pro of JB4 is the ability to remove and take to dealer for warranty claims and NOT flagging TD1 due to ecu still receiving stock boost values hence “piggyback” however I could be wrong, not an expert. Just would like to see evidence of TD1 with jb4 being culprit.
It's possible to lean the car out with a JB4. You'd have to fuck up the fuel bias settings, or use a custom boost curve that's extreme. Both problems are on the user.No he can't provide evidence. He's an anti tuner. He said he's seen evidence of a JB4 leaning out. Since a JB4 only boosts the stock tune the stock tune must have gotten severely lean and in that case without the JB4 it would have run even leaner.
