cbenjes
- Bel Air, MD
Is it possible to remove the rear rotors on a Mk7 GTI PP without removing the caliper bracket? Has anyone been successful?
BTW if you are removing the caliper bracket on the rear brakes, go out and buy a 17in breaker bar. You will need to get those bolts out and your average bar is too long to fit with the car just on jack stands.
You're making my C-clamp and Dasani bleed bottle seem inadequate
I read to use a jack to loosen the bolts somewhere. It worked for me.
PP rear brakes on the R is the same as the Audi 8v S3 right?
4:50 mark
Was going to take off the triple squares today but couldn't for the life of me fit a ratchet or break bar behind there due to the suspension - going to give this a try
