looks like you missed the proper location for jacking.
the part that you bent is bent.
not too much to worry about, it will rust a little faster there.
if you like, take it to a body shop and they will tell you how much to fix properly. you then can compare that cost to a little ding no one will see.
and, by the way, I hate when that happens.
Well by the look of it you didn’t jack it up in the correct place. You are too far to the left. As for damage it’ll survive. As far as lifting n the future from there you will need to be careful.
Just to be clear, “too far to the left” from what prospective, looking toward the front or looking toward the rear? Does the jack pad belong more inboard or outboard? Thanks
I guess I went too far left because I put a jack stand to the far right, which also made somewhat of an indentation. Can anyone tell me where the proper place to jack from and place jack stands would be?
I came across this thread http://www.golfmk7.com/forums/showpost.php?p=9208&postcount=13 but was always under the assumption that I could use the pinch weld for jack stands.
That brings up a good question. When putting the car up on jack stands the jack points are not wide enough to both jack and insert the jack stand. So where is a safe spot to jack the car up? When I did my oil change I jacked it up by the frame that it's under the center of the car below the engine
