Oldschoolmk7
- Yonder
Another day another tuned car/clutch thread.
Everyone is different.
If you don't pay attention and roll on >50% throttle down low in the RPM Range in high gears your clutch will be toasted sooner than late.
The driver is by far the largest variable.
All motors and mechanical items will fail eventually. The oem clutch is not a performance clutch. These motors stock, tuned, piggy make a lot of torque down low. It also appears to be a variance in quality control on these oem clutch parts. With that said...
I would agree the driver as stated above contributes a great part because I have seen this phenomenon on multiple platforms (turbo front drive) now. I would say well over half of new owner manual MK7 GTI/R owners (based off many comments made) have felt it is ok or normal to be able to mash the throttle at lower speed in the higher gears (5th & 6th). In fact many users report "checking for slip" by going WOT in 5th-6th which is largest cause of the slip to begin with. That is a clutch Darwin Award right there. Lol.
George Smooth of Burger (if you search/research) has stated this multiple times in clutch threads. It is the quickest way to a short clutch life.
