Hi,
I'm planning to do a retrofit of a OEM highline rear camera and have run in to some questions in my planning
Since I'm currently at a lower budget my plan is to source the wire harness from Aliexpress and buy a used OEM camera locally + OBDeleven for coding.
My MIB2 head unit is a 3q0035824a, to my understanding it should support the camera. I also have parking sensors installed front and rear from factory if that makes any difference.
The wire I'm planning to buy: https://www.aliexpress.com/item/33041466887.html?spm=a2g0o.cart.0.0.33cd3c00nXVHwW&mp=1
The seller informs me this will work with dynamic guidelines saying: "The camera needs to be high configuration [4 lines], support dynamic trajectory".
But what he means by "4 lines" I'm not sure of.
My questions now is:
1) What part number for OEM flip badge camera is the highline version that supports dynamic guidelines? I have access to the following:
Please let me know if you need more info. Thank you!
- 5G0827469F
- 5G0827469FFOD
- 5G0827469C
- 5G0827469E
