Thanks for the tip. Appreciate it.
Thanks. Does the inner bumper (front and rear), usually have markings for sensor locations ? Especially the 4 sensors that goes on the sides of wheel wells ?Np, Tell me if you need anything else.
Yep, all the holes are marked.Thanks. Does the inner bumper (front and rear), usually have markings for sensor locations ? Especially the 4 sensors that goes on the sides of wheel wells ?
If not any clues for positioning the holes ?
Thanks., still debating weather to get the VAS-XXXX tool for punching sensor holes on the bumpers (which by the way is close to $ 180) or just get a conical step drill bit and get it done.
I have the bumpers clear bra (PPF Protected)., so little to nervous to insert the drills
Happy to help, I hope this could help others who would want to install this too.thanks for the information, that was very helpful.
Thanks, I was planning to tap it from that location as well. I am still in the process of ordering the parts from AliExpress which usually takes 30 - 60 days to be delivered.
Planning to do a detailed DIY post on this forum., with lots of pictures.
There are 2 types of sensors on this kit, 10 regular ones and 2 brown sensors that are a bit taller, these are the two front PLA sensors.Question regarding side sensors for PLA 2.0 (12 Sensor) setup., I am trying to retrofit this on my 2017 Golf TSI (US version, front wheel drive) and ordered the PLA 2.0 Kit from AliExpress.
For the sensors, I received
10 Regular non-recessed brackets
10 sensors - 34D.919.275 A
2 Recessed Bracket/Holder 5GD.919.399 & 5GD.919.400
2 Sensors - 5Q0.919.297 D
I assume that - 5Q0.919.297 D goes on the front bumper on the 2 sides near the wheels.
For the rear side ones, sensor - 34D.919.275 can be used as used in all other positions ? As per the existing DIYs, I see that all the side positions uses recessed/flanged holders.
Can someone please clarify this please ? Attached below is the picture for reference.
No problem, im here if you have any more questions.Thanks for the info., ordered the rear PLA brackets locally and they are on the way now.
