Parts list : Installed on 16' GTI S MT
Purchased from FCPEuro
Audi Clutch Kit - Genuine VW Audi 07K141015BX
Audi VW Clutch Disc - Sachs 03G141031P
VW Clutch Release Bearing - Sachs 0A5141671N
VW Flywheel - Sachs 06J105266AL
Audi VW Shouldered Hex Nut - Genuine VW Audi N10332002
(control arms, maye not necessary but why not)
Audi VW Crankshaft Seal - iAbed 462103171F
(iAbed Billet RMS. Not necessary, but already in there figured why not. This piece is very nice and much more stout than the stock RMS. Hardware included)
Audi VW Billet Rear Main Seal Installation Tool - Genuine Audi VW T2009
VW Audi Axle Bolt - Genuine VW Audi WHT005437
(didn't use these as I did not have to pull the axles from the hub. Just swung off to the side)
VW Manual Transmission Mount Hardware Installation Kit - Genuine VW KIT-MK7MANHRDWRKIT
(trans mount hardware)
Purchased from ECS
Clutch Alignment Tool = Mfg Part #AT126, ES#3437965
Throw-Out Bearing Bolt - Mfg Part #N90847002, N 908 470 02, ES#470959
(new bolts weren't included with the TOB purchased from FCP)
12 Point Socket Head Pressure Plate Bolt - Mfg Part #N90320701, N 903 207 01, ES#4818
(new bolts weren't included with the TTRS PP kit from FCPEuro)
Brake Fluid 500mL DOT4 compliant - Mfg Part #B0007501MDSP, ES#3628353
Dogbone Mount/Pendulum bolts:
Mfg Part #
N91201001, N 912 010 01, ECS Part #ES#2719522
Mfg Part #
N10699401, N 106 994 01, ECS Part #ES#257634
Mfg Part #
N91167101, N 911 671 01, ECS Part #ES#472085
Dropbox link for Vehicle service manuals (torque specs, procedure, etc) =
https://www.dropbox.com/sh/f99kqqmv66pryib/AAA5LM_C4H6x4l56StzU9YO9a?dl=0
Clutch Delay Valve removal. A must if you're upgrading clutch (and haven't done so yet) =
https://www.autoinstruct.com.au/man...mk7-golf/mk7-golf-clutch-delay-valve-removal/
*had the wrong Trans fluid, removed from list.
