Octane Boosters/ Fuel Additives
MK7GTiPP
Union, KY
What are everybody's thoughts on adding octane boosters (the kind you get at a gas station)?
MSchott
Michigan
My thought is it's a waste of money. Put in 91 or 93 (if 91 is not available like in my area) and you are fine. Fuel additives are a different story and may or may not be valuable depending on the age of the car and the detergents in the gas you use.
TwinDad
Fort Lee, NJ
I tried royal purple with 92 octane vs. 93 octane. The royal purple should have raised it to 95 octane based on their claims. I datalogged with a JB4 and saw better timing, less corrections and more boost on the 93. The octane booster is snake oil. Use a few gallons of e85 instead. Won't really do much in a stock tune though
Firstboost
East Bay Area
This is a good answer. Glad you went out of the way to do the research.
MonkeyMD
Just curious. Is there any benefit to running 93 + some e85 on a stage 1 or 2
Hexxum001
Agree 100%. Don't waste your money on octane boosters/fuel additives. Just throw in a couple of gallons of E85 the next time you fill up.
PouncingPanzer1
Without more boost or compression the need is really not there. Personally I would just run the 91 or 93. I run 93 even though I have access to shell 91. I found it to run a bit smoother.
Oldschoolmk7
Yonder
I logged a ton of runs with VP Racing Octanium for other platforms. Turns 10 gallons of 93 into 101 octane. Legit non corn alternative.
MK7GTiPP
Union, KY
Where can I find E85? I have never seen it at a gas station before..
MK7GTiPP
Union, KY
Okay, thanks TwinDad for that test. So octane boosters are a definite no-go. What about adding a gallon or so of E85? I saw some conflicting responses from you guys..
