StorableComa
- SoCal, USA
- 17 GSW S FWD
Good info. Prolly run the Boschs that are in there for a bit longer, maybe till the Is20 files pop and I decide to swap. Been running them about about 2k miles so far, and 600ish miles tuned with no obvious issues. Other than the throttle/accelerator pedal not reading 100 when against the kickdown switch, the Logs seem to be alright so far with 3rd gear pulls.The color on the plug will tell you how they are after about 5,000 miles. If they are darker, it's too cold. You want a nice light brown. I've ran on step colder on is20. I had issues with a set of denso ikh24, and put stocks back in for a bit that were gapped to 0.025. I ran 27 psi peak down to 22 on 40% ethanol no problem. They didn't skip a beat. Got my best dragy time for 60-100 as well. I cracked into the 5's. Not bad considering I'm a full weight sportwagen with the slushbox auto
Slushbox FWD GSW here too. I'll post up when I swap plugs, and pictures of the 4654's after they've had some miles in them when I swap. I assume they'll prolly be black though if their 2 stages colder and most recommend 1.
