Would that be a plausible alternative explanation to what caused the failure?He doesn't necessarily need a new engine. The cylinder 3 coil wasn't grounded and causing misfiring which broke the ring land on that cylinder. It's possible he can just hone cylinder 3 and install a new piston. Someone competent needs to check it.
Twist in the plot. Contacted a local dealer about a 19 GTI. Explained all the details of engine failure. They can give me $11K for the trade in. Should I take it?
There are no free lunches. If they give you more than you think the trade is likely worth, you're taking it up the @ss on the price of the new vehicle, financing terms, or a combo.
this is a decent guess.He doesn't necessarily need a new engine. The cylinder 3 coil wasn't grounded and causing misfiring which broke the ring land on that cylinder. It's possible he can just hone cylinder 3 and install a new piston. Someone competent needs to check it.
I'm saying most dealerships will say new engine because it's less labor costs for them to just pull and replace especially when dealing with warranty work. With this not covered under warranty sure if the cylinder wall damage isn't that bad rehoning the cylinder is an option. But there is cost associated with a tear down and rebuild and a lot of dealerships will price you out the door because they'd rather just pull and replace and not deal with having a bay filled for more profit.He doesn't necessarily need a new engine. The cylinder 3 coil wasn't grounded and causing misfiring which broke the ring land on that cylinder. It's possible he can just hone cylinder 3 and install a new piston. Someone competent needs to check it.
I feel bad for the OP here, but fuck this thread.
1) absolutely inferior tune
2) suspect maintenance from OP, no offense
3) suspect stripped/not grounded coil pack. makes NO sense
4) pay to play. My GSW is tuned, but also paid off. PAY TO PLAY people.
Once again, sorry OP. I do think there is more than enough sound advice in this thread, though. Used motor, indi shop. SELL RUNNING CAR AND RUN AWAY. Best of luck on the repairs.
The trade in is OP's likely best option as it doesnt seem like he can be without a car while the repairs are being done. Trade it is maybe marginally less financially sound but wins in convenience hands down.
I'd even say the trade is more financially sound if he can get it as it was presented. He stated he owes $16k, they said they'd give him $11k. He'd loose $5k on the trade, presumably rolling that over into a new loan. Fixing it, at a ballpark he was looking at a $3400 engine, and $2700 in labor from a local shop. Just over $6k to fix. He might be able to do a little bit better shopping around for both the engine and shop, but I wouldn't imagine too much better.
