Never too earlytoo early to ask about part out?
Mud
Mud
Twist in the plot. Contacted a local dealer about a 19 GTI. Explained all the details of engine failure. They can give me $11K for the trade in. Should I take it?
I'd have it towed to that dealer immediately before they change their mind. Taking a $5k bath of negative equity on the car (since you said you owed $16k on it) absolutely sucks ass. But right now you have a $16k paperweight, that will take at least $5k to fix anyway (unless you can swap an engine yourself).
GOTwist in the plot. Contacted a local dealer about a 19 GTI. Explained all the details of engine failure. They can give me $11K for the trade in. Should I take it?
The dealer needs to show (not "prove") to VW, that the failure is one that is normally associated with a mod and that the failure doesn't happen frequently on stock vehicles.Thanks very much for clearing my head, @cb1111!
According to my USA Warranty and Maintenance booklet, in the section on "What's not covered" on page 7, it says:
Damage or malfunction due the misuse, negligence, alteration, accident, vandalism, or fire
This limited warranty does not cover:
From the language, doesn't the dealer have the burden of proof to show a software tune directly caused my engine damage/failure? By extension of the statement above, there exists "damages NOT resulted from the installed engine management components modifications."
- Damage, malfunctions, or symptoms resulting from modifications of the vehicle, including but not limited to the installation of engine management components, not approved by Volkswagen
What happens if I tell the dealer that, what proof do you have that it is the software tune that caused my engine failure, not a "defect in manufacturer's material or workmanship"? Can you say conclusively that ALL engine failures like mine that you've seen are from tuned vehicles?
I expect the next post to be about the new to you 19 GTI.
This time make sure you dothe maintenanceNOT DO ANYTHING TO VOID YOUR WARRANTY!!!
Actually it is. While the burden is on the manufacturer initially to show that the defect is not covered under warranty, as soon as the dealer says "the failure is normally associated with this mod, we warn the owners not to do it", then the burden shifts to the owner to show that the mod was not to blame.I'm not quite sure that's the letter of the law, but in application of the law, I agree. In this case, it's wouldn't matter, the dealer has an open and shut defense. ECU was altered and the factory ECU was no longer able to operate within factory perimeters, which are designed to prevent knock and excessive heat. As a bonus, you'll get to pay THEIR legal costs.
OP, hone, new piston, flash back to stock, move on with your life.
Assuming that they are giving you a decent price on the 19, I'd jump at that deal.Twist in the plot. Contacted a local dealer about a 19 GTI. Explained all the details of engine failure. They can give me $11K for the trade in. Should I take it?
