In regards to running a 91 tune with 93 octane. You can argue that you have a type of safety blanket, sure. The real gain will be the fact that you can beat it longer before she starts pulling timing and or boost. I’m not sure if the ea888 also pulls boost.In regards to detonation/knock and running a 91 tune with 93 fuel:
Correct me if I'm wrong, but doesn't a higher octane basically allow for greater compression without detonation (the igniting of fuel in cylinder based on compression and heat BEFORE the spark plug is supposed to ignite it)? By that regard, by running the higher "unnecessary" octane, you are giving the engine a greater safety margin?
On the contrary, diesel motors do rely on detonation for ignition as they do not have spark plugs.
Am I on the right track?
fa20 wrx’s on a 91 tune running 93 octane have interesting logs. The car’s dam fbk and fkl are steady as you’d expect but at wot the car advances all the timing it possibly can that the 91 octane tune would allow.
