My MK7 GTI Build is Done! Beast!
Nickpapzdcr
MA
It took about 3 years to build but I finally finished it. I went to the track once with a apr stage 1 tune and lowering springs and immediately fell in love with racing. My goal was to build a track car with my GTI. Here’s my mod list!
MOD LIST:
ENGINE:
IS38
APR ECU 93 Overrun File
APR TCU
APR downpipe
APR Intercooler
AWE Track Exhaust
Spullen Charge Pipes
APR Boost Tap
APR Intake
APR Turbo Inlet
Spullen Catch Can
NGK race spark plugs
RS3 Coil Pack
Racing Line Oil Cooler
P3 Guage
Motul 5w30 Oil
ECS Intake Air Duct
BRAKES:
APR 6 Piston Brakes
APR Track Pads
MOTUL Fluid
SUSPENSION/HANDLING:
APR Dogbone
APR Pendolum Mount
034 Engine/Transmission Mount
APR Rear Sway Bar
Euro code Front & Rear Strut Brace
KW V2 Coilovers
034 Camber Plates
034 Subframe Collars
034 Strut Mounts
034 Sway Bar End Links
White line Ball Joints
R888 Tires (On Oem Wheels)
VMR 710 Custom Painted w/PS4s Tires. ( Daily Driver Set)
No Rear seats
OBD11
COSMETICS:
Aerofabb Front Splitter
ECS Tuning Carbon Side Skirts
BMP Tuning Carbon Mirror Caps
Aerofabb Rear Diffuser
Maxton Design Spoiler
RFB Headlights
Tint
Xpel on Front End
Fusion Ceramic Coat
Pinalloy Carbon Paddle Extensions
ECS Folding Mirrors
Aluizio
Brazil
MOD LIST:
ENGINE:
IS38
APR TCU
APR downpipe
APR Intercooler
AWE Track Exhaust
APR Boost Tap
APR Intake
APR Turbo Inlet
Spullen Catch Can
RS3 Coil Pack
P3 Guage
Motul 5w30 Oil
ECS Intake Air Duct
BRAKES:
APR 6 Piston Brakes
APR Track Pads
MOTUL Fluid
APR Dogbone
APR Pendolum Mount
APR Rear Sway Bar
KW V2 Coilovers
034 Camber Plates
034 Strut Mounts
No Rear seats
OBD11
COSMETICS:
RFB Headlights
Tint
Xpel on Front End
Fusion Ceramic Coat
ECS Folding Mirrors
Hi! I'm building a Gti for track days here in Brazil. My mod list is:
ENGINE:
IS38
Armada (Brazil) Remap (350 whp)
downpipe
CTS Intercooler
Spullen Pipes
Racing Line Oil Management System
NGK RS7 plugs
APR Coil Pack
Racing Line Engine Oil Cooler
Motul 8100
R600 Intake
GEARBOX:
Armada (Brazil) TCU
Wavetrac LSD
BRAKES:
Macan Brembo 4 pistons calliper
345 mm Disk
MOTUL RBF 660
Racing Line Dogbone and Subframe mounting
KW clubsport 2 way Coilovers
A048 Yokohama Tires
OZ Leggera 18"
No Rear seats
VCDS modification on Brakes and XDS
I´m with a problem with the DSG. At the end of track days, my DSG started to bounce (when moving the lever from to D or R, or during 1 to 2 or 2 to 1 gear changes). After a couple of days running the car, it returned to normal operation, but the next track days the same problem happened again, until one track when the problem persists and the gearbox did not stop bouncing.
I replaced the 2 solenoids that control the clutch, but it did not solve, so I replaced the mechatronics and the clutches for new ones.
Last weekend I did the first track day with the new parts, and, at the end of the day, the DSG started do bounce again... after some minutes, it stopped to bounce and is working properly. My concern is if after some more track days I'll have the same problem that costed me a lot of money...
I suppose this problem is caused due to high gear oil temperature at the track.
Do you have this kind of problem or know someone tracking a Gti that had similar problem?
Dog Dad Wagon
Go Birds
16 Touareg TDI
why is your DD set the performance wheels and the track set the OEMs? other than the performance wheels looking a helluva lot nicer :D
cbr600rr
Ottawa, Canada
^ probably because he expects the track wheels will get beat up after all the tire swaps. (Also track driving is tough on wheels in general - lots of opportunity for chipping)
Fancy wheels are for looking good on the street. (I do the same with the fancy wheels vs OEM wheels on my motorcycle - OEM for track)
Will_
SF Bay Area
2017 GTI S DSG
Yea but I mean if you’re tracking a lot might as well get a lighter, wider wheel. The stock wheels are like 25lbs and 7.5” wide. Makes a huge difference going to something lighter with room for more tire.
GTIfan99
I bought 2 sets of RE71R's, one for street, one for track.
