AlexRok
- Eastern Canada
Hi,
This week I installed an OEM IHI IS38 from FCPEuro and a Unitronic Stage 2+ 91oct Tune on my 2018 GTI MT. I also installed brand new NGK 95125 (Stock Replacement Ruthenium Spark Plugs) with gap checked to .028" . The car has 65,000km. It had a JB4 from 5000-45000km and Unitronic Stage 2 from 45000-65000km. Never had this issue however on the dyno getting stage 2 baseline numbers it did misfire once and but started up with no persistent codes and the codes did not return on subsequent runs. I never got this on the street before on stage 2 including multiple track days and 20,000 km.
Previously I did have my spark plugs gapped down but for 2+ I decided to not gap them in line with what I understand to be unitronic recommendations.
The potentially relevant mods: R600 Intake, Wagner Intercooler, BMS Turbo Inlet Pipe, Trackslag 4" Downpipe, Fluidampr 551231 Crank Pulley. I did not adjust waste gate but checked and it is ~3.55v via ross-tech vcds.
I've driven the car about 50km, one or two pulls, but finally got the car out and did some wot pulls. Once I finally had some open road the car had an EPC light at about 5k RPM. On the ECM I got a few fault codes on VAG COM : P130A 00 [096], P0303 00 [100], P0304 00 [100], P0302 00 [237], P0300 00 [096].
Obviously the car isn't happy and it seems cyl 3 and 4 misfired at about 5k rpm and the cylinder 2 misfire was at about 700rpm, all at same km- obviously the cyl2 misfire code came on when I had pulled over directly after this occurred. When I was driving it, on some pulls it felt like it was stuttering before it threw an epc light. I also noticed a few codes for o2 sensors and o2 sensor heater.
I'm a bit spooked by this and I'm not sure what it could be or where to start to chase this down. Any suggestions would be appreciated. it was an OE IS38 so I did not adjust the waste gate arm. I do have ross tech, veepeak and the unitronic connect cable. I'm not sure if I should adjust the waste gate arm but it appears the voltage is in line with where it should be. Nor, am I sure if I should gap the new plugs or try the old ones out.
Any and all help or suggestions are appreciated
