Chris: OK
OBD11 tells the user the GIL status of each module. Look again at your OBD11 Control Unit screen - notice the color of the circle surrounding "16" for the Steering Column module
This is how the colored circles indicate the module's GIL (Gateway Installation List) status when using OBD11:
So, the black circle on the Steering column module means that it is in the GIL - but check if there are any other modules registered using my instructions below. Remove any other module until (and if) they are actually installed
Does this hex16 module have heated steering wheel facility? If so, the pin-out is different to your list
Also, have you actually generated a T15 Voltage rail on the test-bench - meaning a switched voltage?
And, i'm not sure if making "a bridge between pins 3, 4, 5 and 6 to simulate ignition" will work. This set-up means that the simulated ignition process happens at the same time that the power-supply to the module is energised (and probably before the T15 pin is energised). This is NOT what happens in a real car! As I said in my previous reply, my suggestion is to use a 4 x pole, single-throw switch
Don
PS: As general instructions for adding/deleting modules on a test-bench (in the future) - this is the process for amending the GIL when the module count changes:
Don
- Fire-up OBD11 software and connect to the test-bench
- Go-to the Control Units screen (the screen in your picture)
- Make a list of those modules that have a YELLOW colored circle - these modules are probably NOT installed in the test-bench, but they have been included in the GIL
- Make a separate list of the modules that have a WHITE, or BLACK colored circle - these modules are installed in the test-bench but are NOT included in the GIL
- follow the steps in the pictures below to access the GIL
- Amend the GIL according to the lists created in Step 3 & Step 4 above
- Go back to the Control Units screen and re-check that NONE of the modules have BLACK, WHITE or YELLOW colored circles
