Hey Monkey, it may have been some DMs we had about this last year lol
You can adjust the Distance Impulse number with OBDII or VCDS...
The answer to how the DIN relates to wheel size is here:
https://forums.tdiclub.com/index.php?threads/distance-impulse-number.316833/
My car (2016 USDM Golf R MT) had the setting "3" (equiv. 1958mm circ.) but the 235/35/19s OE wheels are 2032mm circ.....
For the first couple of years of owning the car I would always notice my speedo read
slow, not fast..... around ~1.5% too slow, which eventually I tested... pretty much as expected if you look at the DNI... has anyone else seen this? setting 3 on their car as default?
Maybe someone changed it on mine...? Because everyone here says their speedos read fast from factory. When I changed it to the setting 4, for the tallest tires 2082mm... it then read around 1% fast, which is fine by me.... I may retest this to confirm, but i remember being pretty clear cut....
