swcrow
7.5 GTI
What tire pressures are you guys running? I was doing 37 like it says on the door frame, but noticed the tires wearing out quicker in the center. Lowered it down to 34.5 which resulted in tons of wheel hop throughout most of 3rd and 4th gears
38 cold.....running DWS06 so I'll keep an eye on center.....
viewsonic
DE
2018 GTI - 6MT
Anyone know the best way to remove/replace the fog light trim on a MK7.5? Can it be done from the outside with trim tools?
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
I think that would be damn near impossible. The fog light, fog light trim and some other plastic bits all kind of mount in the same places, almost to each other in some cases, and there are bumper supports and the fog lights that are held on with screws that you'd only be able to access from the back. I removed all of the plastic trim off my old bumper when I had a new one painted. Since I was putting the plastic trim from the old bumper onto a new bumper I cut most of the bumper tabs on the old bumper with a dremel to get the trim pieces off. I can't imagine getting them free while trying to preserve the bumper tabs.
I think you're best bet is to remove the bumper and work from the back side. You'll need a lot of trim tools or a lot of hard plastic pieces to hold each bumper tab out while you work across until you get get sections free, if that makes sense. It's not the most fun you'll have working on a car.
Edit: Here's a shot of the back. The trim piece you're referencing is gone but you can see all the tabs it locks into.
viewsonic
DE
2018 GTI - 6MT
Thanks for the info and the picture. I thought it was a long shot. Looks like the bumper is coming off...
DSC808
HI State
2016 GTI SE MT
Do I need a spring compressor (or 2x4) to remove my EMD springs/Bilstein B8? Should just come out? Gonna replace the strut mount/bearing.
Kdubya
Florida
2017 GTI
Spring compressor
berserker6
South Jersey
2018 Golf R
How do you like the b8s with your springs? Miss the DCC at all? I'm due to replace shocks and going back and forth between b6 and b8
DSC808
HI State
2016 GTI SE MT
No DCC with the SE.
DSC808
HI State
2016 GTI SE MT
CaptainRatty
Winston-Salem, NC
MK7 GTI
what could cause cylinders 2&3 piston heads to look super dirty/nasty and yet cylinders 1&4 are really clean?
No answer for you, but what made 2&3 look dirty? Caked on carbon?
