So, golf R is there a way outside of VCDS to disable auto start stop on car power on?
Maybe a menu setting I haven't found yet?
Sent from my SM-G960U using Tapatalk
Unplug the thin wire off the battery terminal.
Thank you for that. Any guesses how much cooler IAT's I would get with a FMIC versus mounted in the OEM position?
I think depending on what you’re getting now and what unit you have now they would only lower when you’re using the AC, since the heat from the condenser gets pulled through the intercooler In the stock location. the benefit of the factory location is that you are getting room for a much bigger core which is a big factor with cooling since you have a much larger surface area to cool.
The FMIC location is close to maxed out with the vibrant from Jake and the treadstone for LTM. Jakes is 661 cubic inches and treadstone is 655 cubic inches VS something like the Wagner stock location at 1040 cubic inches.
I have an AMS IC now. It doesn't say how much it flows just that it flows 64% more then stock. And being in Phoenix I am using the AC 9 months of the year.
Yeah I’m in Vegas so I’m right there with you.
The AMS site says “more than 16” and more than 24” wide with a 2.25” thickness, so being generous and saying 16.5x24.5 its at 910 Cubic inches.
I can’t answer if you will see better results with a smaller FMIC or even if you do they may be nominal.
Nice part is you don’t have to have all the labor to remove the existing one you have and you can try out with an FMIC and if it’s not worth it you can remove and not be out much money after resale.
Mine took me less that 2.5hours to install on my own and taking my time.
What is the longest length of TIME you guys would let pass between oil changes? I drive regularly, but low mileage - usually less than 8k miles per year
Cool, thank you.That's not that low. Just change it every year then.
Cool, thank you.
I said low because my insurance wants to default me to 12k per year every renewal. Sometimes I drive closer to 5k but since I got the GTI I do a lot more backroads runs than I used to.
My insurance with State Farm’s bases on 6500 miles per year. Where in No CA do you do backroad runs? I have been doing East Bay hills (San Fran Area).
~2,000 miles on the tires that came new on my car. I want new mo bettah tires..
Any idea how much I could get for my current tires to help offset the cost of the new ones?
How / where / who should I sell them?
