imthanick_a
- Ohio
Stupid question that I thought I knew the answer too but now I'm having my doubts: What turbo does the 2016 GTI use? K03, K04, IS20, or different?
IS20Stupid question that I thought I knew the answer too but now I'm having my doubts: What turbo does the 2016 GTI use? K03, K04, IS20, or different?
17 Instruments
16 Security code 20103
10 Adaptations
(9)-outside_temperature-p_ice_warning_exit_temperature
(10)-outside_temperature-p_ice_warning_entry_temperature
Lowest temp we can use is -9
Have tried this a few times without avail.
feelsbadman.
Doesn't work on 17's+
Sent from my SM-G930V using Tapatalk
Stupid Q: Is there a way to make it so that the MIB 2 only rotates through SET radio stations? I only use like 6 station settings, but the damn radio wants to rotate through all of them!
@nd Stupid Q: Anyone else noticing that while it may remember the last station you were on when you start the car back up, the moment you use the 'Next' button on your steering wheel it jumps to the FIRST station? I notice this happening when I last left it on station #3.
I think so...under radio settings either favorites or station list.Stupid Q: Is there a way to make it so that the MIB 2 only rotates through SET radio stations? I only use like 6 station settings, but the damn radio wants to rotate through all of them!
to cut it to 6 set them multiple times IE 1,2,3,4,5,6,1,2,3,4,5,6
No issues here. What year is your car? Did security code get accepted?
or you could expand your musical tastes.....that's more of a work around than a solution, but if I don't find any other way, I guess I'll just do that
