Diggs24
- de plains! de plains!
- 2015 GTI
A bigger turbo.Buying a used turbo, more specifically a jhj is38 from a 2019 s3, what should I be looking out for? (Currently have a 2019 7.5 gti)
A bigger turbo.
After considering the same thing, generally, I have to advise the same.....you sure you want to just stop with an IS38? if you go just a tad bigger, you'll essentially have same spool and hold for higher speeds. Diggs and at least 4 other members have persuaded me to go that route
Some guy on Facebook marketplace is selling a is38 with 10k on it for 400$ soo it’s more of a deal then anything. I’m in Canada and can’t use e85. I was under the impression going vortex will really shine with ethanol.After considering the same thing, generally, I have to advise the same.....you sure you want to just stop with an IS38? if you go just a tad bigger, you'll essentially have same spool and hold for higher speeds. Diggs and at least 4 other members have persuaded me to go that route
I meant as in buying a used turbo. Is there something specific I should check before buying used.A bigger turbo.
With or without wastegate? Shaft play, any damage to blades, etcI meant as in buying a used turbo. Is there something specific I should check before buying used.
Any notable plastic intake elbow replacements out there that aren't $130 OEM? I suppose something machined would be fine too.
I see a few of the machined alibaba ones on there marked up about 40%, but not sure anything promising.Pretty sure I remember someone on here reviewing some super cheap ones from Amazon
All the way at the top, but I think that's very kind of you to offer, thank you.I still have my factory intake hose at home- depending on where you live in Bama?
Guess you’re paying for the shorter ship times.I see a few of the machined alibaba ones on there marked up about 40%, but not sure anything promising.
says the guy with a profile pic of a teenage girlLowering the car is out of question as I’m too old for teenagers stuff.
