Should I be concerned that my shifter will occasionally give a harsh vibration when going into neutral? 2018 6MT gti.
It has happened a few times before, where I'll be in gear and coming to a stop, press the clutch fully in and then shift into neutral, but it seems like there's a resistance and the shifter will shake around until I "force" it fully into neutral. It's not difficult to get it there, but it does require an extra nudge.
Most recently happened today going from 1st to neutral in slow traffic and I think that is when it usually happens but I can't be certain it hasn't happened during other shifts too.
Tried searching the forums but all I found were issues regarding the clutch pedal, not the actual shifter.
Edit: forgot to add that I recently installed the holy shift short shifter kit and I thought that fixed the issue, that maybe it was the linkages needing to be reset, but today was the first time it happened since installing the kit about a month and a half ago.
