Anyone run an 8mm spacer w/o a lip on the rears w/o issue? Looking at adding 3mm front, 8mm rear.
I’m running 12.5 mm up front and 20 mm in the rear stock wheels?
Not sure if your asking about the lip on the actual spacer or not ..
https://www.golfmk7.com/forums/index.php?threads/my-upgrade-log-non-pp-to-pp-brakes.355770/Here’s a dumb question: what parts would actually be involved with switching a non PP GTI to a Performance package brake system?
Is it as simple as switching calipers/rotors and calling it a day or is there a lot more involved in regards to what needs to be done? (New control arm/new knuckle/new hub..etc)
What does this do / solve?Anyone tried out Savanini subframe collars? I know the Tyrol sport kit is the go to, but Curious if this may be worth it for the price.
https://www.aliexpress.com/item/33009968022.html?spm=a2g0o.productlist.0.0.443d2e90XwxozF&algo_pvid=af67b3af-aabe-4149-8e79-32affc2dddd7&algo_exp_id=af67b3af-aabe-4149-8e79-32affc2dddd7-17&pdp_ext_f={"sku_id":"67166220178"}&pdp_npi=1@dis|USD||30.03|||||@2103399116518646762358657e991d|67166220178|sea
Edit: doesn't look like they come with bolts, but for 66 bucks for front and rear I'm tempted to try them.![]()
From tyrolsport:What does this do / solve?
I was thinking that too. The Racingline kit is aluminum too after some research. Tyrolsport is Aluminum brackets with bronze collars, which is stronger than aluminum after a quick google, and is cast.I was more comfortable using steel material on the collars, versus a softer material like aluminum.
I was more comfortable using a steel material versus a softer material like aluminum. But I’m just an internet warrior, not a engineer.
But give them a shot, they look like all the other look-alike parts on aliexpress.
The only thing I experience from the bullet list above is the very last one, the rest I chuckle at.
Paging all the Chinesium experts: When you find 5 listings for what appears to be the same exact thing on AliExpress how do you decide which one to try your luck with?
@Acadia18 for his expertise in this area.Paging all the Chinesium experts: When you find 5 listings for what appears to be the same exact thing on AliExpress how do you decide which one to try your luck with?
He uses the seller that calls him friend the most.@Acadia18 for his expertise in this area.
I have the motive bleeder. Only used it once so far but it worked perfectly. It's the only one I've ever used so I dont have anything to compare it to, but there were no issues using it.Power bleeder- better to get the motive euro bleeder, or the black label bleeder?
https://www.fcpeuro.com/products/power-brake-bleeder-motive-mot0100
https://www.fcpeuro.com/products/european-power-bleeder-black-label-motive-products-mot0109
