sterkrazzy
- United States
- Turbo. Blue.
I wonder what you actually get if you order that lol
It doesn't say an amount and it's so cheap.
Was wondering that myself. It's popped up on a few sites.I wonder what you actually get if you order that lol
Yeah - that's all I found too. I can't find more information than that but it looks (from the model number) to be 0w20 - so the wrong thing for the 2019 1.8 Alltrack.Was wondering that myself. It's popped up on a few sites.
Not taking that bet because you are most likely correct. From everything I can find, it looks like it is 508 spec 0w20.I'd bet that's a billing code for bulk oil. Or maybe I'm wrong and they send you a little .75oz bottle of 508.
The part code on the SO for my recent 15K service is G E60 020 1B DSP - 0W20 Engine Oil. It's priced at $13.75 retail, $11.38 invoiced. The CA and US codes are probably different?Not taking that bet because you are most likely correct. From everything I can find, it looks like it is 508 spec 0w20.
I really get annoyed when dealers do this kind of simple stupid stuff.
Thanks - and that would be great for vehicles calling for 508 spec oil - but the 1.8 in the Alltrack requires 502/504 oils.The part code on the SO for my recent 15K service is G E60 020 1B DSP - 0W20 Engine Oil. It's priced at $13.75 retail, $11.38 invoiced. The CA and US codes are probably different?
I've got that one, but it is quite a bit larger. I wonder if it fits - same thickness (20) but different diameter (32 vs 25). Maybe I'll just go and buy a 2025...2032 maybe
I seem to recall that there was a second keyfob battery that worked. We need a CR2025, but there was a different battery that had a bit more oomph that fit but was a tad larger.
What battery is that? I seem to have every coin cell battery in my battery box except the 2025....
That was it. thanks. I've bought 4 2025's and swapped them out - one was a muRata battery and the rest were Panasonic - so none original - both cars were built early 2019 and the one with the dead battery was new when I bought in february 2021 while the second was first registered in Oct 2019I haven't had my VW fobs open, but... 2025s are thinner than 2032s. 20 is the diameter in mm, 32 is the thickness as 3.2mm; this is 25 as 2.5mm in the case of a CR2025.
https://www.farnell.com/datasheets/1496883.pdf
A CR2032 has more capacity due to the extra thickness; both are ~3.0V. CR2025 = 150mAh, the CR2032 is 210mAh.
Thanks for the correction too - I had the dimensions backwardsI haven't had my VW fobs open, but... 2025s are thinner than 2032s. 20 is the diameter in mm, 32 is the thickness as 3.2mm; this is 25 as 2.5mm in the case of a CR2025.
It seems odd. The spec is for 5.7l of oil... Maybe that's how they bill against a prepaid maintenance plan? Not on mine though.OK, but 58 of them? Are they billing in tenths of liters?
