Passing or failing will depend on the inspection station, but it is a fail able offense. With that being said, swapping tailights on the mk7 is one of the easiest tail swaps in recent memory. Nothing hard about it.
Hey Claude -- I got them off ebay; part #s are 5G0945095Q and 5G0945096Q. They were very easy to install, the old ones just unscrew out and these go in their place. You do need a harness (@ZERO815 makes them and is amazing to work with) but you can also just re-pin two wires in the connector pretty easily as well if you're comfortable with it. Some coding was required but I was able to do it all with OBD11 (and the aforementioned Zero's great instructions on how to do so.)Hello bob. From whom did you buy those taillights? How easy to install? Any custom harness required? Any coding required?
Sorry for the questions but I would appreciate you sharing some info before I go ahead and spend money on this.
Thx in advance.
Claude.
2019 GTI in Canada
This is the one thing I don't get... because Audi's have them, my wife's Q5 and almost every one I see in the streets have the sweeping turns, the only difference is that in the US the light is red instead of amber.It's illegal because they're not DOT marked. The sweeping signal in particular doesn't meet DOT regs for lit area at first turn on. Also side marker regs. I turn off the sweep when bringing it in for inspection, haven't had a problem in 4 years.
How do you turn on/off sweep? Is it one that easily can be done in OBD Eleven?It's illegal because they're not DOT marked. The sweeping signal in particular doesn't meet DOT regs for lit area at first turn on. Also side marker regs. I turn off the sweep when bringing it in for inspection, haven't had a problem in 4 years.
It's because the Audis flash a full signal along with the sweepThis is the one thing I don't get... because Audi's have them, my wife's Q5 and almost every one I see in the streets have the sweeping turns, the only difference is that in the US the light is red instead of amber.
I'm going to have to look at them again, never noticed that. I guess that's why Toyota does a reverse sweep, turning full and then sweeping to off.It's because the Audis flash a full signal along with the sweep
Thx bob. Much appreciated.Hey Claude -- I got them off ebay; part #s are 5G0945095Q and 5G0945096Q. They were very easy to install, the old ones just unscrew out and these go in their place. You do need a harness (@ZERO815 makes them and is amazing to work with) but you can also just re-pin two wires in the connector pretty easily as well if you're comfortable with it. Some coding was required but I was able to do it all with OBD11 (and the aforementioned Zero's great instructions on how to do so.)
Thx a million lordnikon288. Much appreciated.
Yep, this is correct.It's because the Audis flash a full signal along with the sweep
Adaptation. It's whatever one you set to "100% dynamic" depending on your wiring.How do you turn on/off sweep? Is it one that easily can be done in OBD Eleven?
Is it possible to set both turn signals statically when emergency lights on? (while maintaning individual turn signals dynamically)Yep, this is correct.
A deep socket lol?
1:02:50. Does anyone know what's the exact name of the tool on the video? I have nothing for now.
Thanks lol. I was wondering the size as well though. Do you have idea what mm or inches should I get?A deep socket lol?
