I live in an area with quite a few hills and driving at 0430 in the morning......the auto leveled headlight height was a shade too low for me, so after poking around OBD11 and asking a few more knowledgeable folks than me, I had success with correctly adjusting the headlight level and having the adaption stick. Below I've tried to describe and show a screen capture for what you'll be looking for.
Notes: I left my car running during this. I also used a permanent marker to mark "true north" of the adjustment knob, so I could track how far I turned the knob.
Here we go:
1. Navigate to control units, once connected to your car, under garage (pic 1).
2. Then navigate down towards the bottom to find "4B" (pic 2).
3. Select "Basic Settings" from the menu (pic 3).
4. Select "Basic headlight settings" (pic 4).
5. Press and hold the green check mark.
6. Press the back button.
You're going to see an AFR Error message pop up on your dash.... Don't freak out.
7. Go to the headlights and stick the Allen wrench in the adjustment knob.
8. Turn COUNTER CLOCKWISE to raise the beam. I needed two full rotations to raise just enough.
9. Go back to your OBD11 and select "Acknowledge basic settings" (pic 5).
10. Press and hold the green check mark.
Once complete, the new height has been properly stored. Log out.
Turn the car off, and then restart and watch the auto level raise to new desired height.
I also included two pics at the end, for those that aren't sure where the adjustment knobs are.
Here we go:
