MK7.5, 7 Speed DSG question
Dax5
Burleson
2019 GTI SE
(USA) So I got my 2019 GTI all ready to change the DSG fluid. I'll be honest, I never really paid attention to the gearing as I assumed it was a 6 Speed DSG like I had read many times, and manual shifting is rarely a thing since I drive it back and forth to work. Turns out my GTI has a 7 speed gearbox and so the DSG fluid change is 80K not 40K, however the book clearly states that the 7 speed is the GOLF R only. The whole setup is very different to the 6 speed as far as filter location and you have two spots to drain from instead of one (stand pipe included). Can anyone explain this oddity to me? Thank you ahead of time.
Ghawk
Ohio
2015 GTI, 2019 GLI
No idea why your manual says R model only, but all ‘19+ GTI and GLI models models use the 7 speed Including my ‘19 GLI Autobahn. My manual refers to gears 1,3,5 and 2,4,6, no mention of a seventh gear. The 7 speed DSG played a lot into my choice of car and transmission. Apparently the manuals were published before the decision was made to use this gearbox. I don’t believe there are any VW products using the 6 speed since the 2018 model year. I also own a 2015 GTI with the 6 speed manual. My GLI Jetta consistently gets 10-15% better gas mileage because of the extra gear. About 500 rpm lower at 75 mph than the GTI. 👍
Zodiac
North Carolina
I got an addendum to the owners manual mailed to me about the 7 speed DSG correcting the issues from the error.
yungaxel3
SF Bay Area
2019 GTI DSG
Does it say 80k miles?
Corprin
Magrathea
A car
2019 Alltrack used the 6spd.
coniglio rampante
Austin Texas
2019 GTI Rabbit Edit
80k miles? I thought it was 40k? What’s so different about the 7 speed dsg vs the 6 speed dsg?! It’s the same fluid, no? Is capacity much higher in the 7 speed?
There's no way I would go 80,000 miles on the same fluid. But that's just me. My 18 SE says to change it every 50,000 and I get it changed every 25,000 miles.
Keehs360
Denver
Mk7.5
Smart. Once it’s tuned or abused frequently, one should shorten the interval. I plan on doing mine later this year. Before winter, after the track season
dequardo
America’s Dairyland
‘21 GLI Autobahn GLI
50k? Have only seen 40k specified.
sstarrx2
Davidson, NC
2021 GTI S DSG
I think that 80,000 is based on the car being just a DD and not tuned or driven hard. Many cars have 80,000 intervals for TF and it perfectly fine.
